baboos_boat
I spoke to Richard Reynolds at the factory today discussing modifications on a TC. One modification I am strongly considering is to eliminate the water based marine toilet and replacing with the composting system discussed on other forums.
Now the shower. Is there any reason the hot water routing could not be so I could hook up a shower over the swim platform between the engines? What I woud like (or I am thinking its a good idea) is to have the hot water "tap" around the transome area. Then with some pvc piping I would rig a shower off the back.
My motivation is to avoid all possible water usage and leaks associated with typical marine toilets and showers.
With no toilet or shower the holding tank becomes un-needed. Could that area be used for something else? Like storage?
Any thoughts at this early stage of purchase would be much appreciated.
