Active member
So I am thinking about getting a dinghy and a small motor. I re read a lot of old post on the subject and i think that a 8 to 9 fter will do the trick and keep the weight under 75 lbs. I should be able to manage that. So now to choose a motor and after looking around I see that yamaha has the lightest 2.5 at 37 lbs but thier 4 and 5 weight the same at 60lbs. So if you can get more hp for the same weight why not? any down side and is 60 lbs to much to move around. I think that i could use my pot puller to lift and lower the motor in to the boat.
