It's all in the name - help with finding a good vinyl
bshillam
Good morning C-brats. I sit here in at my desk, the sun is shinning, warming my backside and I begin to daydream about the next outing this Sunday.
Anyhow, on topic....We've choosen a name and I am searching the net, found several sites that allow for you to customize a vinyl sticker. My questions are,
Which sites have you used to order your vinyl and been happy with?
What size letters did you order for your name and port of call?
Before placing an order I wanted a personal referal, I don't want to have to take them off once on. My Heaven needs to know her name. :smilep
Thanks much!
We ordered our thru www.BoatUS.com. They give good discounts for BoatUS and Coast Guard Auxiliary members.
Instructions for dry/wet installation were provided. 5" lettering works well on a 16' Cruiser. It took us less than 15 minutes to put them on.
If you want something a little more custom might I suggest http://www.cohodesign.net/index.html Brad's a great guy. He does absolutely awesome work. He can design something for you if you want. He'll also apply the graphics. He did mine and If I remember correctly it was around $250 installed.
There are two colors each layed down seperately.
I waited for a boat show. Had them made while I watched and also benefited from the advice given by the person making them. I liked looking at different fonts, colors and ideas. I just couldn't find what I wanted to do on the net. Then I brought them home and put them on crooked :roll: Root canals, lortab and lettering don't mix. It seemed like a good idea at the time though. :smile I figure no one will be able to tell as long as I keep moving.
The lettering is on the signature below.
I had Tom-a-Hawk's name made and installed by "Prism Graphics" of Seattle. They were quick and accurate and did some great graphics work in matching the TomCat logo. Pretty reasonably priced also.
Well, I used a signmakers website to figure out what I wanted. Then I went to the closest sign shop. For about $50 I got the boat name and reg numbers, all on application paper that even I couldn't screw up.
We designed ours our selves, had them made by a close friend in ca. with a sign shop, fly her and her boy friend up to put them on and visit. Price was about $400 for the flight, free graphics, and a good time . See ablum for full install pics.[/img]
Most of the good sign shops use the high quality marine grade vinly. The fancy places will charge considerably more. We have found that all of them hold up well. Since they are on "backing paper" and you float them on with a water based solution and then squeegee them out to adhere, the application is fairly easy. I use masking tape to mark the points which are level and parallel. I measure the position of the name first with a ruler/tape, then put the masking tape down as a reference.
As it happens I've got a business that makes all sorts of signs, mostly vinyl.
Here's my two cents -
Start with a great graphic. You can do it with any number of fonts or go for something really custom (like "Playin Hooky - very sharp). There are many great designers to be found on Craigs List. Many work for short money.
Once you've got the design any good local sign shop will cut the vinyl. Buy the best exterior vinyl they offer - the difference in price is usually pretty small.
Installation is really simple but most shops will send someone out for a fee.
If you choose to apply it yourself, be certain to really clean the surface before application. We supply our take out customers with a squeege. Be certain to get out all the bubbles. Use a razor if some prove troublesome.
Finally, even the best exterior vinyl may curl along the edges over time. Simple fix is clear nail polish. :thup
matt_unique":3e3i1jfd said:
Do most owners try to match the lettering with the side stripe color or just use black (to match the Tomcat/C-Dory lettering)?
Matt-
I think most folks try to use the trim color of the boat because it simply looks better.
The letters can also have a boarder around them and shadowing, as well as a whole bunch of special effects.
Designing your own lettering can be a fun, creative process!
Download one of the programs or go onto one of the sites and try out all the various possibilities!
Here's one that works well: Speedy Signs, Inc.
A computor sign guy in Ocala, Florida did " Mis Dee" and the state numbers for both side for $40.00. Two colors, I thought it was a steal now I know it.
captd
matt_unique":sdgg69jv said:
Does anyone know of a site with a good color match to the "C-Dory Green" trim?
I don't. However, I emailed a photo to Brad at coho design and he used his computer to match the color. I'm sure any good sign shop can work with you to get it right.
