New (to me) boat in Anacortes - Where to get kicker?
NewMoon
I am in the process of changing boats, after 25 years as a trailer boat cruiser. It'll be a big jump this time, to a 37-foot Nordic Tug. New Moon will be for sale.
I'm thinking of mounting a 9.9 High-Thrust Yamaha on the swim step for salmon trolling. Any recommendations where to get the kicker? The NT is in a slip in Anacortes.
EQ Marine is near Anacortes (a few miles away). They sell Tohatsu - a very reliable engine. They have a 2015 used (1hr) engine for sale on their site right now for "$2900.00 offers accepted". See - http://www.eqharbor.com/Outboard-Motors-for-Sale.html. They've always done right by me and many, many C-Brats.
Bayside Marine in Everett, WA about 45 miles south of Anacortes. Sometimes have good used Yamahas. Yami 9.9 high thrust, great motor!
NT 37, wonderful boat!
Forward your add for "New Moon" so we can see it. That boat is a really great hull, lots of memories for you. Lots more to come on the Nordic Tug!
Hi Richard,
Glad to hear you are getting a new boat. Do we C-Brats get a chance at New Moon. I have followed all of your posts along the way, here and elsewhere. When you set a price, give us all a shot!!
Bob Jarrard
Congrats! The NT 37 is very nice
Check the Tugnuts forum to see if any owners have done this or have thoughts
I bet the main engine would throttle down to a good troll speed without spending a dime and keeping the o/b off the back, rarely do you see diesel tugs with kickers, not sure if a 9.9 would do much on the big NT but I'm no fisherman
Sam Landsman on NT 37 Safe Harbour and CD 22 Retriever is a great wealth of info
Best of luck
George
Thanks all, very much - I am excited!
I wrote up a description of New Moon, below.
New Moon is a Bounty 257 Offshore Pilot, 25'7" hull length, 8’6” beam. With bow pulpit and swim step about 29’ overall. Built for us in 1997/1998 by Bounty Motor Yachts in Central Point, OR. Green hull and white topsides. Buffed annually with 3M Finnesse-It, and then waxed. Boathouse (garage) kept in dry-air Utah.
She's heavily built, all hand-laid top-quality fiberglass. 11,000 lbs on the water fully loaded for a long Inside Passage cruise. Draft with drive down is 3.5', transom deadrise is 19 degrees - she crushes a short chop.
Nearly 12,000 lb on the triple-axle Pacific Trailer, 33’ feet long, and nearly 13' high. About 75K miles on the trailer by now – scrupulously maintained, with new disc brakes and actuator in 2014. Our tow vehicle is a 1998 Ram/Cummins 2500 pickup with “camper” rear springs, and it works really well. Dually not required.
Power is Volvo Penta KAD44P-DP-EDC, electronically controlled straight six 24-valve 260hp diesel with duo-prop sterndrive. 6,500 hours on her so far. Engine’s belt tensioning system has been upgraded to VP’s newer and more robust design, tightened with a torque wrench rather than hex keys. Dual switchable Racor fuel filters. Reverso gear pump for changing engine oil. Maintenance records are complete and detailed.
The 44 diesel has way more torque than a big-block gas engine. Heavily loaded, she cruises slow at 6-6.5 knots and gets 4-4.5 nmpg. Or she planes at 16-18 knots and gets 1.8 nmpg. Max speed fully loaded is 25-26 knots at WOT. Diesel tanks are 60 gal on the starboard side, 50 gal on port.
Kicker is a Yamaha 9.9 high-thrust electric start outboard, on a robust motor bracket that is easily raised or lowered. Kicker gas is in a 10-gal partition of the port-side fuel tank, with its own main helm fuel gauge, and a Racor fuel filter.
House battery bank is two 12v g31 Sears Platinum (Odyssey) AGM’s, new in 2014. Starter bank is two 12v g34 Platinum AGM’s, new in 2014. The engine’s stock alternator has been replaced by a Balmar 75A alternator, with a Balmar MaxCharge 614 regulator. Fully recharging depleted house batteries after a day or two at anchor takes only 1-2 hours underway. Inverter/charger is a Heart Freedom 10, with a Link 2000 controller and amp-hour monitor. Charger is 50A at 12V. Shore power is 30A.
She has three helms, including one in the cockpit, and a small "tuna tower" upper helm. She's a bit small and narrow for a full flybridge, so Bounty designed a sturdy and light weight aluminum upper helm which seats two, or three in a pinch. Very nice in warm weather, such as at Lake Powell. There’s a bimini top of green sunbrella, same color as the boat covers (not installed in above photo).
Steering is Teleflex SeaStar hydraulic (cylinder rebuilt in 2015). Helms have VP’s electronic throttle and shifting. Main and upper helms have engine gauges and trim tab controls.
Main helm electronics include a Furuno 1732 4KW dome radar, Simrad EQ32 fishfinder, Garmin 2006C GPS/chartplotter with detail chips covering the Inside Passage. Icom M127 radio with hailer, and a top-notch Cel-Wave 9’ antenna. There’s also a Kenwood AM/FM/CD, and a powerful two-bulb searchlight, steerable from the inside helm.
Upper helm has a Lowrance 28XC-HD fishfinder/chartplotter, which covers coastal US and BC (there’s a BC chip), as well as interior lakes, and topo and road mapping.
Forward dinette seat has a switchable seat back, so that it can become a forward-facing co-pilot seat for two. New Moon sleeps three adults – the dinette converts into a comfortable 7' long bed.
She has a Norcold fridge with freezer, two burner Princess propane stove, deep sink, water heater using either engine heat or shore power, a Pur/Katadyn Powersurvivor 40e watermaker (rebuilt 2015), and a Sealand Traveler head with both pumpout and underwater discharge. Fresh water tank is 36 gallons, and the water heater holds 6 more. Cockpit shower with hot and cold. Cabin heat from the engine is Heatercraft, quiet and effective. The windshield defogger takes air heated by the engine and pumps it through a plenum under the dash to three outlets, one for each windshield – also quiet and effective.
There are many drawers and cabinets - lots of storage for a 26-footer. Interior is formica and teak, with “mouse fur” insulating the v-berth hull surfaces. She holds heat very well, without condensation. Ceiling is beige with teak battens. Interior is very functional, and very nice looking. Large sliding windows with screens, and bow hatch is screened too. Seat cushions are a tan sunbrella, all except port side of the helm seat, which has been re-covered in nicely matching leather.
Ground tackle is 300’ of ½” three-strand nylon spliced to 42’ of ¼” HT chain, and a Rocna 10kg (22lb) anchor. Lewmar (originally Simpson Lawrence) 600GD horizontal-axis windlass, with rope/chain gypsy and drum as well. Controls at main helm, with foot switches at the bow. Backup anchor is a 7.5kg genuine Bruce, with 260’ of ½” three-strand.
Fishing gear includes four rod holders built into the gunwales, two gunwale-mounted Scotty rod holders, rod storage for four more rods, and two Scotty Strongarm downriggers.
There are very extensive spares, including another Balmar alternator, another starter, props, belts, and many others.
Congratulations on the Nordic Tug purchase Richard! Will be interesting to hear what your plans are for future cruise adventures.
Have mixed feelings about the kicker idea. I started out using the kicker to troll with because the Yamaha 115 would not idle down to a good salmon trolling speed but after repowering the 200 Etec Will push me right in the perfect sweet spot for salmon at idle. I like to troll at 1.7 to 2.1 mph.
Advantages are
1) don't need to be out in the weather running the kicker
2) much better control of the boat
3) can use the autopilot pattern feature
I run a zigzag when looking for fish then do 15 minute circles once I locate a school. You can do this with a dedicated kicker AP like a TR1 but you have less control in wind or current and they are somwhat expensive.
Anybody looking for a trailer cruiser would be smart to give your Bounty a hard look. Turn key operation and well thought out package.
Something to be said for auxiliary power value though.
stevej
Richard,
Good info on Blue Moon. Does the price you are shortly going to tell us include a copy of your book? I know we can all afford the book!! Great write up on your boat. Hope the new boat is as nice, it will be soon in any case.
Bob and Kyung Jarrard (not really selling either the wife or the dog - the dog has already said she likes this boat!!) BJ
Thanks again folks,
In hindsight, it occurred to me that I might be stretching the limits mentioning that New Moon would be for sale. Since I have alrady made that mistake, and there's some interest, I might as well provide a revised version of my writeup - I keep thinking of stuff I forgot to say earlier. Can provide other info via PM or email.
New Moon is a Bounty 257 Offshore Pilot, 25'7" hull length, 8’6” beam. With bow pulpit and swim step about 29’ overall. Built for us in 1997/98 by Bounty Motor Yachts in Central Point, OR. Green hull and white topsides. Buffed annually with 3M Finnesse-It, and then waxed to a good shine. Boathouse (garage) kept in dry-air Utah, typically from mid-September to mid-May.
She's very strongly built, all hand-laid top-quality fiberglass. 11,000 lbs on the water fully loaded for a long Inside Passage cruise. Draft with drive down is 3.5', transom deadrise is 19 degrees - she crushes a short chop.
Stainless hardware includes large solid cleats, and all-welded one-piece large diameter bow rail, side rails on the cabin, grab handles at the rear of the cabin, and ladder to the upper helm. There’s a very sturdy ¾ length swim step (to leave room for the kicker), a nice transom door, and a telescoping boarding ladder.
Power is Volvo Penta KAD44P-DP-EDC, electronically controlled straight six 24-valve 260hp diesel, turbocharged and supercharged, with 290 duo-prop sterndrive. 6,500 hours on her so far. Engine’s belt tensioning system has been upgraded to VP’s newer and more robust design, tightened with a torque wrench rather than hex keys. Dual switchable Racor fuel filters. Reverso gear pump for changing engine oil. Maintenance records are complete and detailed.
Kicker is a Yamaha 9.9 high-thrust electric start outboard, on a robust motor bracket that is easily raised or lowered. Kicker gas is in a 10-gal partition of the port-side fuel tank, with its own fuel gauge and Racor filter. An EZ-steer connects it to the stern drive, so that it can be steered from any helm.
She has three helms, including one in the cockpit, and a small "tuna tower" upper helm. She's a bit small and narrow for a full flybridge, so Bounty designed a sturdy and light weight aluminum upper helm which seats two, or three in a pinch. Very nice in warm weather, such as at Lake Powell. There’s a bimini top of green sunbrella, same as the boat covers.
Steering is Teleflex SeaStar hydraulic (cylinder rebuilt in spring 2015). Helms have VP’s electronic throttle and shifting. Main and upper helms have engine gauges and trim tab controls.
Main helm electronics include a Furuno 1732 4KW 24-inch dome radar, Simrad EQ32 fishfinder, Garmin 2006C GPS/chartplotter with detail chips covering the Inside Passage. Icom M127 radio with hailer and fog signals, and a top-notch Cel-Wave 9’ antenna. There’s also a Kenwood AM/FM/CD with Bose speakers, and a powerful two-bulb searchlight, steerable from the inside helm.
House battery bank is two 12v g31 Sears Platinum (Odyssey) AGM’s, new in 2014. Starter bank is two 12v g34 Platinum AGM’s, new in 2014. The engine’s stock alternator has been replaced by a Balmar 75A alternator, with a Balmar MaxCharge 614 regulator. Fully recharging depleted house batteries after a day or two at anchor takes only 1-2 hours underway. Inverter/charger is a Heart Freedom 10, with a Link 2000 controller and amp-hour monitor. Charger is 50A at 12V, powered by 30A shore power. Shore power can also run the water heater and refrigerator, and a small electric cabin heater. Two 110V double outlets, at front and rear of cabin.
She has a 3.1 cu. ft. Norcold DE541 fridge with freezer, two burner Princess propane stove, deep sink, water heater using either engine heat or shore power, a Pur/Katadyn Powersurvivor 40e watermaker (rebuilt 2015), and a Sealand Traveler head with both pumpout and underwater discharge with macerator pump. Fresh water tank is 36 gallons, and the water heater holds 6 more. Cockpit shower with hot and cold. Cabin heat (from the engine, like a car) is Heatercraft, quiet and effective. The windshield defogger takes air heated by the engine and pumps it through a built-in plenum under the dash to three outlets, one for each windshield – also quiet and effective. The three windshield wipers are pantographic.
There are many drawers and cabinets - lots of storage for a 26-footer. And lots of storage under the cabvin sole. Interior is white formica and teak, with “mouse fur” insulating the v-berth hull surfaces. She holds heat very well, without condensation. Ceiling is beige with teak battens, and hangers for five fishing rods. Interior is very functional, and very nice looking. Large sliding windows with screens. Bow hatch is screened too. Seat and berth cushions are a tan sunbrella, all except port side of the helm seat, which has been re-covered in nicely matching leather.
Ground tackle is 300’ of ½” three-strand nylon spliced to 42’ of ¼” HT chain, and a Rocna 10kg (22lb) anchor. Lewmar (originally Simpson Lawrence) 600GD horizontal-axis windlass, with rope/chain gypsy and drum as well. Controls at main helm, with foot switches at the bow. Windline BRM2 anchor roller, with a bail added. Spare anchor is a 7.5kg genuine Bruce, with 260’ of ½” three-strand.
Fishing gear includes four rod holders built into the gunwales, two gunwale-mounted Scotty rod holders, “rocket launchers” for four rigged rods, and two Scotty Strongarm downriggers. There’s a raw water washdown hose in the cockpit, and a live bait bag which attaches to the back of the transom, each with its own pump. There’s also a fish-cleaning slot with drain built into the top of the transom, and a 30 inch cleaning table with a mount that fits into the built-in rod holders. Forward of the engine in the cockpit, there’s a large fish well with drain and macerator pump, which can also make for a good storage compartment.
There are extensive spares, including another Balmar alternator, another starter, another windlass, props, belts, impellers, filters, and many others.
Book is included :D
