Donald Tyson
If I attached a stainless bow roller to an aluminum deck plate would I need to isolate them somehow against corrosion? Some charts online say yes and some no. It seems to me that there would be issues.
srbaum":1mjt63q6 said:Another method to isolate is to coat all cells contact surfaces with Lanocote. It’s inexpensive and has been used in the maritime industry for metal isolation for years. I have a 4 oz tub of Lanocote and a 4 oz tub of TefGel. I coat every metal fastener with Tefgel and all larger metal surfaces with Lanocote. This even includes trailer work.
Peter & Judy":19uihp65 said:I have used Butyl 2 sided tape when attaching things like my swim ladder to the deck. It should provide isolation between the layers and is waterproof as well.
Donald Tyson":uwv34dqx said:If I attached a stainless bow roller to an aluminum deck plate would I need to isolate them somehow against corrosion? Some charts online say yes and some no. It seems to me that there would be issues.
clayhubler":1rsxfr7e said:There are different grades of stainless also and the lesser grades will rust too. Even high grades that are contaminated with carbon steel will get rust spots on them. Contamination can happen simply by using the same saw or file that has been used on carbon steel.
My roof rack and fillet table bars have rusted even though I used 316L grade tubing. I have wondered if there is anything I can do to prevent this. Is there a conditioner oil or wax I could apply that would make a difference? I notice the bow rail never looks rusted but it also kind of looks like it’s been electro polished.
thataway":3ml8b13j said:I have used Collinite 885 Fleetwax on SS, after cleaing with the Collinite SS cleaner. I also use Collinite wax on my fiberglass. They have specialized products which work well.
I try and avoid any SS fittings made in China--even some labeled 316 have had more corrosion than I find expectable.
