Since I had the Coastal Explorer system all humming along fine on the Windows laptop, I thought I would see if I could just use my Mac running OpenCPN as a drop-in replacement if necessary. Turns out I can! Boris, I still reserve judgment on OpenCPN until I have seen how it actually works on the water, but works great in my garage! But I am pretty sure I now have two fully functional computer nav systems working!
I first headed over to ftdichip.com and downloaded the Mac USB to serial driver. I knew what I was looking for because of my experience with the Coastal Explorer Windows computer driver for the Digital Yacht AIS / multiplexer, same download page, different driver for a different computer but for the same purpose. Easy-peasy.
I turned on the C-80, turned on the AIS / multiplexer (I have that on the breaker that was for the head discharge, it was unused since I don't have a marine head or macerator), started OpenCPN, and plugged the USB cable from the Digital Yacht AIS / multiplexer into the Mac. After a quick stop in Setting to select the /dev/usb-adapter device or whatever it was called and set the baud rate, bingo, everything showed up on te Mac OpenCPN screen slick as a whistle. There is my boat on land just off Birch Bay in the same spot Coastal Explorer showed it!
It was a little more difficult to get the USB monitor working. I thought it would be a simple matter of installing the driver, which I download from displaylink.com. No she go. Back to Google, where I discover my error - the Mac setting page with check box to "Mirror display" (the Arrangement tab of the Display settings) only shows up when the external monitor is actually plugged in. I had been trying to do the settings from the comfort of my couch, which of course was impossible. Out to the boat, plug in the monitor, go to the Arrangement tab and check the "MIrror display" box and and we are in business!
The magic key to all of this is that slick little Digital Yacht AIS / multiplexer that is the link between the C-80 and the computer(s). Four wires to the C-80 NMEA cable (two input and two output), two wires to power, and a USB cable to the computer. The key to making this little gem work is NOT to use the Digital Yacht drivers but head directly to ftdichip.com to download drivers, whether Windows or Mac. Still an excellent purchase by me![/color][/size]
