clayhubler
After my complete refit of Hammerhead, I find I have a bunch of 'stuff' taking up space in the shop. If anybody sees something they want, just make an offer. Smaller items can be had for shipping cost, or picked up from my home in La Center, WA.
Wallas 95D:
This stove was working when removed. It had some issue where it was overflaming, and making a howling noise. We took it to scan marine, and they did some work on it and told us that it needs a new control board, which is not available. They got it working better, and said that it would work until it didn't. They said it was safe to operate, and would likely continue to operate for years. The unit itself, along with the exhaust hose, thru-hull, and controller are included. The fuel tank is included if you pick up from the house. It is not installed, so you cannot see it run, sorry. If you get it and it doesn't run, bring it back and I'll give you your money back.
Hydraulic 12"Wx9"L trim tabs:
Complete except for the hose. They are boat leveler company. They worked fine when removed.
Magma BBQ mount, for a flush rod holder:
BBQ not included! Just the mount!
Raymarine C120 MFD:
I have the power cord and a bracket that will allow you to mount it above the front windows. Or maybe you have the exact same unit and just want a spare???
Raymarine radar:
I don't really have any data about this. I believe it is 2008 vintage. It was working and connected to the above C120 when removed. Probably best for local pickup. The cord is intact and included. You will need to reconnect inside the radome.
Radar tower:
Local pickup only, tower only. Pole holders and vhf antenna not included.
Wallas 95D:
Raymarine C120 MFD:
Raymarine radar:
Radar tower:
